Is it possible to do this by removing the calipers and spray painting them for a better finish?
is spray painting the standard 172 brake pads (front and rear) an easy task to do?
That will look sh*t.I have a flame red 172 and was going to do calipers bright red..![]()
Yep...
This thread reminds me of that one ages back where someone painted their discs red, brilliant!
..i was hoping you could of been a little more blunt m8, u dont need to go easy on me.
...i think sum1 needs a tug!! :rasp:
.... yeah now quote the rest of what I said..i was hoping you could of been a little more blunt m8, u dont need to go easy on me.
Bit of a contradiction there, is it just the red hammerite that isn't heat proof ? I thought they were all ok up to a certain temp ?? (I know that hammerite isn't high temp paint)Don't use Hammerite as the red stuff is not heat prof, use heat resistant caliper paint. Alot of people have used hammerite and they dont seem to have had any problems, its up to you, the right choice is Caliper paint but no one has had a problem with hammerite.
Yes it did because I didn't understand what you were saying, hence why I asked.Its radiator paint, its not as high temperature as the heat proof stuff which irrc is only in silver or black. I would never use nor recommend the stuff on my brakes but as you have referenced in the above post its fine, I was stating I would not use it but I have heard people have not had any problems with it.- did that really need to be explained?
Lol, i've written in about 90% of the other threads.All is explained in numerous other threads on the same matter. That was just a quick summery.
.... yeah now quote the rest of what I saidselective quoting ftl.
Anyway red will look sh*t.
