Vista Help!!
Car  Blown up 182 & Mondeo TDI
Ok trying to install Sims2 on to my nieces computer and there is no option for installing?
The disk autoruns but instead of loading as i does on my XP machine it just comes up with the autorun menu. I have searhed google but no real answers.
Go to My Computer (just 'Computer' in Vista) Right click on the CD/DVD Drive and click Open
Then once you can see the content of the disc, double-click on "Setup" or similar.
The usual, play with media player, explore etc.
When i explore there is no setup.exe or the like as there is when you run it on XP
Never really used Vista, is there any other things i should try?
Which Sims are you trying to installed?
Sims, Sims 2? Expansion Pack..?
Sims 2, its on DVD not the CD version
Only one Vista account so i asume it has administrator rights?
If you go Start > Click on the Display Picture it should link you to Control Panel > User Accounts. It will show you on that menu if you are Administrator or not.
I take it you installed Sims 2, not a Sims 2 Expansion pack?.. Obviously if you are installed an Expansion pack you need to install the Sims 2 core game first.
I can't think of any reason why it shouldn't work, when you explore, do you see any Files/Folders? or does nothing appear?
There should be a Autorun.exe or Setup.exe somewhere..
There are 6 folders, if you open the autorun.exe it simply brings up the menu again
It is the ful game not an expansion
