who paints the bullets n how much?
Car  Italian 3.2 V6
thinking flame red to match car and either white or anthracite for the lettering/numbers!
let me no ;)
diy
easy might be a painting guide somewhere on here
i found warming them up helps the paint take better
will work out much cheaper diy have a go if it fails then buy some
Try Mish on here mate, sure she will do some for you if you dont want to do it yourself
Darn it beaten to it ^^^^^^ EDIT !!!!! LOL :)
I did the bullets and front badge anthracite with flame red lettering, looked smart, sold them on to bens_172 on here, he has some pics up
Middo did mine m8. Not sure if he still does them though? Might be worth a PM?
D.
might try and do it myself... so whats the correct way to do it? and how do u remove the bullets from the car?
Use your hands to remove the bullets. Pull up from the bottom. Using your hands makes it less likely to break the clips i think. Worked for me anyway:)
If that doesnt work try using a screwdriver wrapped in something so not to score paintwork or anything.
i've just finished doing mine :) i managed and i'm s**t when it comes to spraying.
i used a plastic primer after a quick rub down :p
then colour coats which i left to harden
then using a touch up pen of the right colour i hand painted the lettering.
then a couple of coats of laquer. job done!
ok cool thanks alot m8, im assuming this would be the same process to repaint the front main renault diamond? rub down, primer, pant, laquer?
guess so!
p.s. thanks to ChrisD cos he told me how to do it in the first place :p
