Upgrading from Vista 32Bit to 64Bit
Car  Tesla MP3 2021
I plan to upgrade to the Vista 64Bit version soon and from what I have ready some people recommend to use the Windows Back up feature currently in Vista. This isn’t a problem as I have a 1TB USB HDD it can go on but I was just wondering if this is actually necessary.
Can you just upgrade to it and roll back if there are any issues?
When you install you can get it to put everything in 'Windows.OLD' folder but don't format it...
You could also use the built in windows backup to create a backup onto your HDD then if anything fails you can restore from that using the Vista CD
I decided to do a fresh install in the end rather than an upgrade. The 64bit version appears to be alot quicker already :)
There isn't any performance difference between 32bit and 64bit, its just because you have done a fresh install that its quicker :)
^ Wouldn't there be more RAM available if the OP has 4GB of memory?
Yes, but this would be countered by the larger 64-bit processes. Until you cross 6GB (as you have to do matched pairs), I'd say stick with 32-bit.
Well I have put all my programmes I had on before and it is still running quicker. Even file transfer rates have improved
id have stuck with vista 32bit not much difference between then 64bit will be faster, but finding programs is normally the hardest bit.
Personally id wait till Windows 7 is fully released then get 64 bit OS.
Vista has so many issues and causes so many crashes its unbeleavable.
windows 7 (i'm using the beta release now - Upgraded from Vista Ultimate)
is so much faster then vista could dream of.
Im using the exact same spec as what i was running vista and it runs like a dream. So much quicker at everything. to the point that when you turn it on you feel happy that Vista aint gonna try and control everything for you and generally just annoy u.
Must admit there is some issues with Windows 7 but as of yet have been alot less then when a i Brought my retail version of vista.
Which i my opinion is a vast improvement and it just feels fresh new and simple to use.
All just my opinion of course.
