Had the car on the rollers today!!
Car  Clio 182
Tbh i wasnt sure what to expect.....
Mods are an RStuner and a cat back K-tec stealth..
Really wanted a de-cat before but couldnt source one in time...
Lol dunno really, just under 180 maybe.......
Defo going to go for some matched inlets as well as some stage
what kind of rr is this?
131.6/129 atw with a cat back and RS tuner?? dare i say seems a little low...
i make that as 155.2bhp at the flywheel....
As said in the other thread, im always a bit funny with motorscope results, but in comparison to others from there looks like a healthy result.
Agreed with the ATW and Fly figures though, but i feel that all motorscopes at the Fly figures are calculated really high
2.6 hp difference between the wheel readings? but only 0.7 difference between the fly?
am i being dumb or is that not right?
i spotted that. TBH there's margin for error, and heat can change things between runs. that's a tiny tiny difference
barometric pressure looks too low though
Tbh the rollers seem accurate, my friend has a 2.0 20V turbo coupe which he had rr'd as 255bhp a few months back at a different place, had his done here today and came out with the same result.....
thats a bit of OTT for a FWD car, 25-30bhp is about the going rate
either way, don't take that print out as gospel!
So what are saying mate, should i getting way less power than that??
What should i be aiming for with the mods i have then
Well the wheel figure is going to be the most accurate.
so 131.6 + 25 0r 30 ish.
Front wheel drive is normally calculated at 17% trans loss IIRC, (awaits Matt fred or another Guru to correct me.
Tbh i would ask Tupps (sure ur friends with him) to have a look at his graph see what his wheel figure is, cos IIRC he had 183 at the fly for a near standardish car.
See what % they used to calculate his at fly figure, would not suprise me if they had used a large % agen on his.
Ok then................. just going off the results tbh..
Most people say that with an RStuner you gain 8 -10 bhp which over standard mine appears to be showing.......
I have a RStuner on mine, and although ppl say 8-10 im still doubtful on it. Feels slightly faster because things are done low down on the revs, and the 5K is more smooth but i dont believe the predictions.
