Running a power cable
Car  Clio 2007
Hey,
I need to get a power cable ran from my battery to power an amp in my boot in a Renault Clio 1.2 turbo dymanique 57 plate.
I am using 2 awg cable and I need to get a single feed to the boot. Any ideas how I can get it from the engine bay into the car itself?
Danny
there is a a hole were some wires go through the firewall to the battery behind the dashboard, get a torch and look up behind it and your see it, best way would be to just push the wire through there.
the dude's got 2awg cable... thats guide's gonna be useless to him.
with such thick cable, you'll have to get the drill out and make a new hole in the bulkhead through to the engine bay. Drill the hole, buy a gromit to fit in it and feed your cable through this way.
I just had a look at my bonnet release cable and it looks like this:
How do you get a power cable through that?
Just going through the same problem, on my Ph1 though, find a gromit that goes into the wing? Wierd.. Anyway, does anyone kow if that guide will be similar for the Ph1?
Is there not a guide in the guides section. Pay the 10a and you will see all the other guides to!
i got 4awg through mine no problem. slit a hole in it with a stanley knife. vaseline up the cable and poke it through.
Real men can get 0 guage through, no danger!! :rasp:
Real men don't use a drill, they use an angle grinder and homemade grommets.....;)
A few pics of a dumdum wiring job:rasp:
Take one battery
A few cable tidies to erm, support cable:rofl:
A grommet in the boot floor
Then start wiring:clap: 30 runs of Knukonceptz 0awg....
