Alpha Wecon P1042 ECU.. Mapping for ITB's help
Alpha Webcon P1042 ECU.. Mapping for ITB's help
I was wondering if you can help me out folks.... I have just bought a secondhand Alpha Gold throttle body kit from a tuned Mk1 Clio 1.8 16V
The problem i have is.. Im fitting the kit to a standard Clio 2.0 16V Williams engine and therefore the map on the Alpha P1042 ECU will not be correct for my engine
Ive been told the Mangament is 10k from webcon and not many tuners have the software
Can any of the tuners on here tweek the map or put a standard williams base map on the ecu
Or any other help would be great... its all pretty new to me :o
Winston
the software is limited to dealers, so you have to pay the price off the dealer for every lil tweak.
you may be able to pick up a hooky copy if you search about...i will ask a mate of mine, i think he has a copy.
It was K-tec that fitted the kit.... The guy i got them from said they knew nothing about the spec... In fact I knew more about the spec than K-tec lol
Cheers for the replys... I will get some research done :D
