Hub Spacers
Car  Bumder With A Buffer
This might be a really stupid question but I dont know the answer myself :o
Got a new set of wheels and when I offered them up to the hub earlier the hub was smaller than the centre of the wheel hub itself... The holes where in the right place for the bolts and it tightened up fine but I took it off as was unsure that it was safe.
Im guessing I should fit hub spacers? And they make the hub larger to enable them to fit tight on the wheels?
No-One?? :(
Basically those wheels and they are multifitment for PCD 100 and 108 which is fine....BUT the size of the centre is larger than the hub on the car. It looks like you can fit something to the bore of the wheel itself to make it fit?
You need spigot rings mate, Have a look on ebay
Ah ha! I was looking at the wrong thing then :o I knew what I wanted but not what they were called!
Im guessing its a bad idea to run on them without those? (just to state they are not on at the moment!)
Second hand dude... either he didnt have them or forgot about them...Il drop him a message and ask actually.
