Oh yeah and that.. Of course.. Mate this is a HUGE drain. I saw it drop out from the book that I had it on and when It fell in, It took AGES for the 'plop' and it's dark
This area is nasty. I'll either find a prostitute down there or some little chav "yo blud, git out mah drain before ya get murked G"
I'd rather pay. Just over 100 Sheets then?
Get the key cut seperately from your existing, just incase the locks were ever changed, probably cheaper too. Then ring up all the accessible Renaults near you for the fob as I found each dealer varied in price, around £30+ difference between my closest 10. Once fob has arrived from France, its needs to be coded, normally only Renault iirc but have heard someone on here knows another place that will do. One Renault dealer actually didn't have the machine to code the key for my ph1! About half hour labour they'll charge, so again ring them all up as I found at least £30 per hour labour charge differences. Then don't be a muppet and walk over drains unless you have a tight grip on keys.
For reference, I paid £38 for coding after my dad had a moan I was a student and they could come down a bit lol and the fob for £77 from £85 as they couldn't code my key there and I kicked up a fuss for wasting my time going somewhere else. Was prob a couple of years ago but don't think prices have changed much on keys.
When i couldn't find my spare key for my 172 i had to go to the stealers to get a replacement and get it programmed, no where local could program it (Locksmiths etc although they could supply the blade).
It was nearly £140
Click this bar to view the full image.
Your local dealer may have to order the key though
My key wasn't in stock and had to come from france or some s**t
Incidentally, if you were to go to an auto locksmith and just get a key that will manually unlock and start the car (without c/locking code), would this then activate the alarm when unlocking manually?
My dad's old car would remember if it had been locked by remote or key-in-door and then if you tried to unlock with an alternative method, would sound the alarm.
