Alarm
Car  Clio 197 R27 Albi
Sometime when i lock the car it beaps at me a few times.
all the doors are shut correctly. but it only does it sometimes?
:S what is this?
thanks
its a common problem. mine does it and it supposedly been fixed twice. if it beeps i just unlock the car then lock it again.
Check the bonnet sensor, Mine used to do it and it was the sensor not sitting in its cradle properly, My 2 pence worth tbh
:S what is this?
thanks
Common problem with them. Its power still running thru the ECU/UCH.
Once you turn off the vehicle and get out, give it a few second to sort itself out then arm the alarm.
I think that produces 3 beeps if you do it too quickly.
And the door ajar is 4 beeps.
(Double check that in the manual tho!)
But its nothing to worry about as long as it arms and works.
Sometimes my car will beep once when i lock or unlock the car, i think i've sussed it though, it happens when another renault is near.
