The day n0rm and bongy did Planktec y0!!
cat171
Great stuff :D
Is the car un-touched suspension/set up wise apart from the coilovers ?
Does it rub/scrape at all ??
Ali
  V6, Trackhawk, GTS
It's more the undertray thats the issue craig...Mine scrapes all the time and i'm not that low.
cat171
True, mine hangs a bit loow as it is. I think I ned to get it off & fit it on again. I was on about the front end, with the splitter the front end is very low (on standard stuff)
  340i
IIRC..... when he first brought the car, he muttered the words... "I am not going to mod or change a single thing on this car"
PAAAAAAAAAH!!! ;)
Nah mate no scraps what so ever at the front, like ali says the undertray scraps abit like.....other than that its sound
Ali
  V6, Trackhawk, GTS
Not sure that would work on track at that height tho. I jacked mine up for the ring and had a few scrapes on the way round.
Agree mate, if i do any track work ill do like you say raise it up quite a way!! Its literally on the lowest setting itll go with out rubbing!!
cat171
With regards to undertray at the back, did you have to remove it at all Norm ?
How does it fit on, is it hard to get off ? (i'll raise the car etc)
Ali
  V6, Trackhawk, GTS
The undertray?! :S Got be confused now! Whats that got to do with the Suspension...
It's about 10-12 bolts, captive iirc. on a ramp with a buzz gun off in 1min flat.
has ali says cat, you dont need to touch it to fit the coilovers, but yeah so simple to remove, there 10 cap bolts holding it that all:).......the only trim that needs to be removed is inside to get to the rear topmount bolts
cat171
Thanks. I thought i'd be cheeky & ask about the under tray while there was mention of it :eek: I need to get mine off.
  172
IIRC nOrm you've already "removed" your rear undertray anyway?? ;)
Was impressed with the KW kit tho, everything went together a treat, the camber bolts worked well, even the bump and rebound were set to the recommended settings from the factory.
Could do with some Hubcentrics at the front, then you can add some more neg camber!
FPMSL ahem thats another story marra;)
More neg camber on the front sir...your a bad influance on me cnut;):cool:
a last few piccys ive just uploaded...includeing a spot on side view to show the height!!:)
PlankTEC y0....
/WIN
  RS6+ & 40d MSport X5
Im changin my ph1's rear back to standard, with the exception of a cup spoiler!
