Setting camber yourself...
  #174
Thought I'd look into this to see if it was possible. Using something like this:
http://www.motorsport-tools.com/ind..._id=87&zenid=a44936758438b8d6dfe943af72ec798f
It can be used for castor and camber. Say if I got that and was able to make a decent job of it, would there be any disadvantage as opposed to taking it to a place that could setup the suspension for me? Without corner weighting that is.
Could even knock up a home made camber gauge pretty easy I guess, but for the price of this I may as well buy one.
Thoughts?
  172 & RSi
How can you measure the camber with a spirit level? Or is that just for getting it a 0deg? Wanna know cause I want to have a go at mine so any help would be greatly appreciated.
  TrackCar & F30 330d
It depends how flat you floor is. The race team i work for have 4 metal plates which are on little feet. We set the floor up to its perfectly flat then we use a didital camber gauge which goes into a triangle frame which we place up to the wheel.
Indeed, I find getting the floor flat to be the hardest job. I will one day set up a true flat patch in my garage....
btw, most digital gauges aren't that accurate (I wouldn't trust one beyond 0.25 deg), they are prone to errors that just can't occur with a bubble.
stand level vertical with the bottom edge against the rim at the bottom, hold the level vertical and measure distance from top of rim to level. I used to work out the angle, nowadays I just work in mm.
I use toe strings to set the toe, 2 poles with grooves cut at the same width, a length of fishing line, and some tyraps to attached the poles to the car front and rear.
  106 GTI
Want to do mine?
dzm
  Inferno 182 + cup packs
If you've got an iphone or itouch there's a digi angle finder app that's very accurate. Of course, the flat floor is the tricky part.
Adjusting camber will affect toe, so you need to adjust toe after setting camber. I got mine done by a guy specializing in race and track car set-up for £50 the other day.
  #174
Bit of a fail on my part, I wouldn't be able to really set the toe with that bit of kit lol whereas obv a setup place will do.
Will see who's local that could do it I think.
  alien green rs133
if you can get an iphone to acurately tell you degree's from north you can set toe at home???
i use tracking gear at work and spirit level for camber :D
