White spark plugs - Running lean?
Paddy_g46
After having the plugs out today to do a compression test the tips of my spark plugs were a bit white, so im thinking the car is running lean.
So what do i need to do to doible check it and fix it?
Patrick
get it on a good set of rollers and get the AFRs checked fella, and see whats what
will any rolling road do this?
plug colour will only tell you roughly what the fueling was doing a few seconds before turning it off
My mate said something like that, so its not so much that the plug is stained over a period of time just at the instant?
If that is the case why do i always read about telling how it runs by plug colour? In a haynes manual for example?
Its true, when setting up a carb on a bike you do a full throttle run but then switch it off at WOT
Long term bad running can cause damage to the plug. There's a few clues can be taken to engine condition, but fueling is quite complex so plugs aren't the way to analyse it
yeah..but standard plugs should be fine..i run colder plugs but only because of the turbo..i think if you are running lean theres a fault somewhere its not because you need colder plugs.
Again talking from a bike backround a friend blew a hole in his piston due to messing with different temperature plugs instead of setting up the carb
