yes I know there 2118's but are they the cup racer ones . . . 43 offset? 15 x 7 inch? reinforced wheel . . .
with a 38 offset they will not be the cup racer wheels
Eh?
Think what you're on about are the palmersport ones.
These arent the cup racer ones. They were made for the palmer trackday cars, with et43.
The cup racers used 2020's, similar offset to cup wheels.
After a while they started using the alloy 2118's as the 2020's cost so much to replace and were pretty fragile in a pile up.
Theres no groove on mine either, the centre caps were a tight fit but i put a dab of superglue on just to make sure they didnt fly off!
On the fronts the centre cap would'nt go on because the driveshaft thread stops the centre cap going on ( obv near the hub nut ) All i did was pop the front of the centre cap off, grinded a hole for the driveshaft, and then glued the front back on the centre cap.
That sounds like bull but i know what I mean!
what size were they? Had a 60mm one that was too small . . .
still dont answer the questin tho
