thumbgrips
  DCi
My steering wheel thumbgrips have decided to deteriorate :(
Is a carbon fibre replacement available yet? Who do I need to speak to?
it depends how badly split they are, so long as most of the rubber is still there I can fix them, however, when you fit them back on they may not fit perfectly back in place...
pm me if you wanna give it a go, personally if k-tec or stremline do replacements then I'd go down that route, but not sure if they do at the minute
T
  DCi
T
I've emailed them both and sent you a PM
Cheers for you help.
iain, your not accepting pms, maybe your inbox is full, can you check please
ok ricky, my solution isnt the best, easiest or probably cheapest, but it is an option if nothing else is available..
T
  DCi
T
Should be sorted now, cheers.
