seat ibiza spacers
  Vantage
i have seat ibiza on a w reg
would these spacers fit my 2002 plate clio
and how do i tell if there hubcentric
Dicky Belly
  Whichever has fuel
Hubcentric bolt to the hub, Good times.
s**tty spacers are just flat pieces of metal that sit between the hub and the wheel. and will give you no end of grief.
  BMW M4; S1000 RR
Depends though, you can't get 5mm spacers that are hubcentric and 5mm isn't enough to worry about anyway, but then I think you can get to 12mm before they start coming in hubcentric (at least that's how Eibach work). And 10mm spacers are indeed a PITA if you don't have studs.
False..
Hubcentric have the same angle on them as the hub "lip"
meaning that there is less strain on the bolts.
What you are reffering to is sytem A and system B spacers.
As I have 13mm system A spacers from FK, they use longer bolts (don't bolt to the hub) but they are hubcentric as they have the hubcentric angle.
