Standard Airbox Feeds
Car  Bumder With A Buffer
Going to get rid of the Viper I have in this weekend and go back to stnadard Airbox with uprated filter instead.
But I got the bad-boy out of the box last night and saw 2 air feed..ones at the front (obvious where that goes!) and one at the back of the Airbox...where the fudge does that one go??!!
I cant remember where it went when I took it off :(
ta daaaaa
This is the back one
Here you can see the front one
Pretty obvious where the front one goes but where the f**k does the rear one connect too???!!
The rear one goes under the main one, there should be a metal bracket with 2 holes that it slots into.
It doesn't attach to anything like the main one does.
Where did you get them feeds from mate and what size do i need?
I bought some 70mm pipe (similar to the ones in the photo)
Il take a pic later on of mine as thats someone elses.
But I believe the pipe in the photos is 70mm as well...its in Jamesstone "go-kart" project thread..about page 9???
Cheers il have a look later.. I literally just looked at the box last night and went.. hmmm how did that connect up again :)
