Go steady with a drill bit slightly bigger than the spot, only go through the weld though, not material behind it.
you will need special drill bits , spot welds are stupidly strong and you will probs end up meltin a few good drill bits like i did lol , think the propper bits are £12 ish each
they've gone down then. Mine were £20 each
Where'd you get em mate??
Grinder with small disk and take it easy, will be gone in seconds![]()
industrial tool supplier
They are the ones you want. If you are using a cordless drill I think you will struggle but I doubt you are.
The slower the better mate nice even pressure.
I have a scar on my wrist where a spot weld drill went in out and back in again!Ta mate, got the bit! Not using a cordless dont worry![]()
Doc said he doesn't know how I missed an artery!
Couldn't stich it so I got superglued up!
Take your time!
if the brackets are junk Id just grind them off.
Yeah kev you can just basically sand down the bracket using a grinder until you grind it off completely. That way you may not leave holes
