brakes
Id go for brembo HC and Ferodo ds2500 pads, thats what ive got and think most poeple would reckommend!
Its also cheaper than renault standard parts.
I'd recommend you search. It's been done to death, must be 3 threads a week about it.
220bhp, what spec??
Most people will say Brembo Max HC discs, decent pads (ds2500 will be high up there) and braided lines coupled with decent fluid and you'd be set.
Alot depends on budget really as obviously 4 pots will reign supreme dependant on how you use the car (road/track etc).
As Warren has said though, this is done on an almost daily basis.
I hope for your sake, you've either got individual throttle bodies or a low comp turbo.
Other than that, best brake combinations to go for are what's already been said^
you will be fine on standard calibres + braided lines, brembo HC + DS2500s.
We run that on our track car and its ideal set up also run same on the road car and stops fine with the extra weight.
am looking at puttin k-tecs new low compression turbo kit on but my brakes are in desperet need of changing first!!!!
Fred could you message me i tried the other day and your box is full. Its about some Brakes and Pads purchase.
