Cruise Control?
Car  Clio 172
Sorry if this is in the wrong section but im confused. I turned the tracion control on (green switch) an i figured out how to use it but what is the orange switch for?
Phrased badly there is one switch but one way is green one way is orange. Im useless with things like this.
P.s this isnt Ben its Matt his mate. Also owner of a Silver 172. Im the one that converted him and will be signing up later this week :rasp:
Its a speed limiter, ie set it at 40 and you can't go any quicker unless you put your foot to the floor. Ideal for specs cameras.
The orange speed limiter won't let you go any faster than the speed set no matter how hard you put your foot to the floor, when in the up position green light on thats the cruise control which you can over ride by accelerating or braking.
Traction control is on all the time unless you press the switch and then an orange triangle appears on the dash to warn you it's off
If you press it right down till you feel the pedal 'click' it will override the function until you slow down below it.
