M Martyn_182 Jul 24, 2009 #1 my v6 airbox arrived today. but i thought it was supposed to be round :S will this one i have still work the same?
M Martyn_182 Jul 24, 2009 #4 Beef-Mc said: I'm guessing that's a Clio v6 airbox as opposed to the Espace v6 one. Click to expand... not sure. just said espace v6 airbox in the add and had a pic of a espace one. looks like it will fit on
M Martyn_182 Jul 24, 2009 #6 just fitted it quickly and took it or a small blast. seems more responsive lower down than the pipercross that was on it. damn tight fit tho
A Andyman Car Ph1 Jul 24, 2009 #7 LOL @ square box Its meant to be round mate. Basically same as a ph1 172 but with single inlet not twin
M Martyn_182 Jul 24, 2009 #10 just found out its off one thats a 1998 to 2003 model. still works ok just need to get a caf pipe for the underside
Chrisjk Car Evo 6, E92 320d Jul 24, 2009 #12 That will be no different to the std 182 air box, you need the cylindrical box as it has a much larger surface area and bigger inlet.
Greeny. ClioSport Club Member Car 440i + 182 Jul 24, 2009 #14 How annoying mate, yeah these are off the later ones Earlier ones are like £65 quid new from Renault.
franx Car RS RIP Jul 25, 2009 #15 the round ones were used on the R25 V6 models (remember those ?) and the earlier Espace V6 models Around '98 they started using the square ones
Wests Renault Car Discounted 1*2 parts Jul 27, 2009 #16 whats the advantage with using one of these then?
R Russ_16v Car 53 Clio's & counting Jul 27, 2009 #17 The box you require is the early Espace,which is the same as the ph1 clio box, just with one larger inlet as supposed to the clio's 2 smaller one. It wont offer much change as it is basically the same as the ph2 box Unlucky really fella, few people make this mistake.
