espace v6 airbox
my v6 airbox arrived today. but i thought it was supposed to be round :S will this one i have still work the same?
just fitted it quickly and took it or a small blast. seems more responsive lower down than the pipercross that was on it. damn tight fit tho
That will be no different to the std 182 air box, you need the cylindrical box as it has a much larger surface area and bigger inlet.
How annoying mate, yeah these are off the later ones :( Earlier ones are like £65 quid new from Renault.
the round ones were used on the R25 V6 models (remember those :)?) and the earlier Espace V6 models
Around '98 they started using the square ones
The box you require is the early Espace,which is the same as the ph1 clio box, just with one larger inlet as supposed to the clio's 2 smaller one.
It wont offer much change as it is basically the same as the ph2 box
Unlucky really fella, few people make this mistake.
