Help needed too hot-heater gone wrong!
Car  clio sport
Hello
Hope someone can help me....My mrs clio sport 172's heat has gone wrong.:(
When you turn the key blower comes on straight away no way of turning it off....also comes on hot no way off turning it to cold....Also cant turn speed down..just on constant
I need help....Please:(
Bradley
whats your location?
Is it a climate control system or poverty spec dials that control the heating system?
More info you give and the more we are all able to help ;)
I'm Chelmsford ESSEX
Not sure?
Its Air Con
I can press the temp up and down but dosent change temp Still Hot
Same with speed control up and down dosent change speed on fast
Hope This Helps
so its climate control if you press buttons to get fan and temp to change with button pressing.
I expect you could have two things wrong, heater resistor fooked and a possible mixer motor failure, could even be the panel at fault.
Needs a clip diagnostic test to see whats causing the problem.
Or you could disconnect the heater resitor which is located under the scuttle panel on the drivers side front as a temp fix but you will have no heating/fan at all, better than getting roasted everytime you drive.
Ive check the control panel and all seems fine,how do i locate heater resitor ?
open bonnet, look at the black plastic bit just under the front screen on the drivers side and remove large plastic panel its under that and has a load of wires going to it.
Have a look in the guides section for changing pollen filter its basically the same, the connector has lugs that you need to press in to remove it.
Ive got it so it is on cold now....any other ideas....
could it be the big yellow fuse thing under the bonnet....when i take it out the fan stops,could it need a new one?
