outer cv boot kit...
Car  Jagggg...missing the 182!
just found a hole in my cv boot, phoned up gsf, dont do the sport ones, they were saying need a whole shaft?
surely not right? anyone bought one from renault? or a universal boot do the job?
def wont be going having my arse stretched to the tun of couple hundred on a new shaft, no chance!
just need to know if you can buy a 2,0 specific boot or have to be a universal strtchy job
renault do a boot kit for the outer. A universal one would work just fine as long as you get the best clips you can find and not cable ties
Kind of related..The Drivers side inner gaiter..is that a git to change..mine is shot BIG time!
Is there a "Bodgable" fix that would do for a bit until sourcing a new shaft?
nothing i've tried so far. A LOT of black silicon sealer over a small hole works for a few weeks if you clean up the boot and rough the surface so it can stick, then let it go off for at least a day before use.
The double bonus of a new shaft is the outer boot on the new genuine ones are rubber not plastic like the shite originals, and also have a proper clip not the ones that always break
Mine held with heavy duty cable ties :S Why not use cable ties?
that's not a servicable one sadly. tried loads of times to find a suitable solution. New shaft is the only proper fix
Why cant you just replace the boot with a kit like this...
http://cgi.ebay.co.uk/STRETCH-CV-BO...TING-CONE_W0QQcmdZViewItemQQitemZ180382878571
Watch the video.
I aint saying I know better or having a go, I genuinely want to know.
This is whats happened to mine :(
Also related I think..my abs/asp and serv light have come on due to grease I think :(
^ Feckin hell Rich mine was only a tiny nick where the outer boot clip is.
ESP & SERV lights were randomly appearing too but went out again when you turned off & on. Haven't came back on since the boot was sorted :)
Looks like new driveshaft time then..I tried cleaning up the abs rings today but that didnt help..im not too worried about driving around with them not working though....cant say I noticed any difference earlier..in fact im sure it helped my braking!
I just had to replace the OEM clip on mine with a jublee clip, Done the drivers side last week and now the passager side clip went that i noticed yesterday.
FFS it was the dirtiest job I have ever done on a car, Green snot all on my wheels, all on the caliper, all on the disc. It never comes off just smear everywhere, Tried Gunk, Auto Glym machine cleaner.
how easy is it to replace the outer cv boot on the passenger side? Take it you have to take the cv joint out as well and put the boot on from the other end? how does the cv joint come out the driveshaft on 172's
