Ph1 172 on TB's
  Honda & VW
Looking at one one pistonhead and do like it but just a bit wary as to how much strain the extra power will be having on the gearbox etc.
What are peoples thoughts on this?
thanks
Lee
wouldnt be any danger to the box unless its been abused already, the box should be able to cope, tbs dont give massive hp increases
id keep ur teg
  B/G 182 + PH1 Track
Well is it, 200Bhp- 215BHP or 230BHP?
Our car has been find on a rebuilt gearbox at 200BHP, Our car only gets driven on track so its hammered very time its out. I did blow the diff though :( oops.
Yosemite Sam
  Whichever has fuel
I personally think unless you know the exact history of the build and the car, then its not worth bothering with.
You could end up buying someone elses trouble!
Ben Spent 000's repairing other peoples f**k ups.
should be ok on standard box as the extra power is linear unlike a turbo so the extra stress isnt as severe.
BUT
as daniel says, unless you know the history you could buy something thats been done badly and piss oil everywhere constantly like a certain itb'd car
  B/G 182 + PH1 Track
Couldnt agree more,
  ITB'd MK1
box life is all down to how it's driven. Dump the clutch everywhere on super sticky tyres and you'll break it with standard power.
  Honda & VW
Well the one i was looking at on pistonheads says "having a new engine put in at the moment(old one suffered a oil Pump failure"
rebuilt with 83mm 12.6:1 compression Forged pistons,
ACL bearings,
ARP 2000 big end bolts,
Cat Cam 421's,
Omex 600 ecu
Doesn't mention service history in the advert.
oh and Tobs - the teg went back in March just haven't changed my avatar etc
maynard
  ph2 172 track car
well for a start its been for sale for 30 days, so seems like something isnt right. is that anyone's off here?
  ITB'd MK1
421s were in the boot last time i saw it. used to be a standard engine with cams, large single TB and an Omex ecu. It dropped a valve head 2 years after it was put together.
  lift number 1 @ btm
i wasn't sure if you meant this thread or the advert, so i thought i should take the piss to make sure:D
an a side note, oil pump faliure leading to a new engine? might be worth checking that oil pressure gauge too?
  lift number 1 @ btm
thats odd.
i've ended up with this advert open on two windows, one with this.
Engine
ACL bearings,
and one with this.
Engine
45mm Throttle bodies
ACL bearings
as above, i'd stay away!
  e60 M5 -172- dciheid
all of this stuff was up for sale last month btw!!! but not fitted to the car
  ITB'd MK1
thats odd.
Engine
ACL bearings,
and one with this.
Engine
ACL bearings
that's properly weird!!! but it's done it to me now.
