Increasing My Wireless Range
E11OOT
Car  182/V6/R27/R26R
Picture describes current wireless set-up at home (RED), the GREEN circle is where i want to add signal to, basically to the out-building.
We currently have a Buffalo Air-Station WMR-G54 and ideally i want to add a booster to the far end of the house, running an ethernet cable through the loft connecting the current router to the booster.
I was wondering what the best products and methods are of achieving this?
A modern more powerful wireless router does not do the job, as i have borrowed a friends to try.
Thanks
I'd just mount an external antenna in the loft with a decent amount of gain if I were you mate :)
A good website for you to look at would be solwise.co.uk
The site seems a little amateur but I've ordered from them before with great success..
trying to get a universal wireless repeater, an external antenna in the loft will not give me the required range due to the materials in the house and the large distances involved.
the outhouse has power but i would need at least 2 of these plugs to get the signal across far enough.
Nope, You plug one into the router directly, and into the wall power socket.
The other end goes in your outhouse.
Be careful of the extenders that use the mains power cables to extend signal. I have heard that they can be good, but the sockets need to be on the same mains circuit, otherwise they don't work so well.
I take it that you are in an old house with thick brick walls?! I work from my parents house, in an outbuilding, and had the same problem. Ended up getting
http://www.pcworld.co.uk/martprd/st...m=null&tm=null&sku=538536&category_oid=-35258
which seems to work quite well, although can be a bit tempremental at times.
yeah the power cabling in the house is all over the place, i think the outhouse is not part of the same system as my house.
The house is all thick oak wood basically and this absolutely kills the signal.
the Belkin thing there would it just connect it to my current wireless router via an ethernet cable probably about 50m long and then place it in the roof at the far end of the house?
As long as they all run through the same consumer unit there's no problem.
i was thinking about one of these...
LINK
Would the system be set-up like this?
Buffalo Router --->50meters ethernet cable---> TP-Link (repeater mode)
At my parents there is the main board, then from there, there are approximately 6 other boards around the house, so difficult to trace all cabling.
The belkin unit I am sure that you can connect via ethernet cable, then basically is an additonal access point, but uses the original router. I have it set up so that it is on the limit of the original wireless. It then picks up the original wireless signal, and boosts it.
Mount a directional antenna outside like below and point towards the Outhouse. It will reach it no problem with a directional antenna
http://www.wifi-antennas.co.uk/index.php?target=categories&category_id=209
OR as above Solwise are good to use as well. Failing that a cat5 cable (up to 100m I believe)
