Nope nothing off the stalk
May be the connector in the steering wheel worked loose. Press the button on the left stalk (opposite side to the trip computer button) as that is the horn as well. At least then you will know what end you want to work on.
Thats a duff button on the mk2 ph2 fella, Horn is on the steering wheel itself,
You might need to pop the old airbag out and check the connections there,
just been out in car kept trying the horn and got it to work just the once then stopped again![]()
