How do i turn off my service light?
Car  Clio 182
I took my air box off my clio 182 today and when i re-fitted it the service light has come on. How do i turn this off or will it turn itself off?
Its not a Service light and its normally caused by a loose connection under one of your seats or possibly low oil.
Could it be because i had only the front of the car up on axle stands so the oil was at one end of the engine so the sensor thought it had low oil?
No because the oil light would be on with it and the STOP light would be on as well as SERV, are there any other lights on with it?
^as above it normally comes out with another light. COuld you have accidently knocked something or diconnected something. Theres the oil level sensor down near the oil filter, than can get damaged easily.
Or the person before you cut out ABS, Airbag or other light so only the SERV has come on?
Its all fixed now. it was cos i had the front wheels off the ground and going through the gears with the esp turned off so it thought it was just spinnin up i think. it went off as soon as i drove the car.
