By now I have stock suspensions and the eibach camber bolts. A friend of mine told me that his Koni Yellows has already teh holes that bring the camber up to 2°...is that right? So if i mount them i should remove the bolts right?
if your talking about front shocks then yes some shocks allow for some degree of camber adjustment with standrd camber bolts(like fk coilovers). however i believe if you wanted to dial out more camber then you would need camber bolts
