Disconnect the fuel pump and start the car a few times until it won't start to depressurise the rail would be a good idea to start with unless you've got a petrol bathing fetish or something.
your car has 4 mate, they are located under the funny metal cover at the front of your engine (the one that gets in the way when removing your oil filter lol)
you remove the two nuts holding this on, undo the clips that hold the wiring and pipes for the rail,undo 2 further nuts, then from memory you pull the whole rail out,(it fits into the lower plenum) then remove the offending injector from the rail
What problem do you have?
why did i not think of that, i wouldnt have got vpower in my eye if id have thought of that!!
Can do either tbh whatevers easiest, you'll be surprised how long it'll run without the pump running if its primed recently. So deffo try starting it 3 or 4 times after it cuts out the first time.
Yes you can see the injector connectors easily once the fuel rail guards off.
#1 is flywheel end in renault world.
If you have a front end shunt it won't break the plastic fuel rail and spray petrol everywhere. So personally i'm under the opinion its best to leave it onOff topic, but what is that for???
Had to remove mine but when it came off, I couldn't see any/much use for it.....
If you have a front end shunt it won't break the plastic fuel rail and spray petrol everywhere. So personally i'm under the opinion its best to leave it on.
How do you get that metal block off as I can't get a tool in the holes at the front to undo the 3 bolts e.g. this is one of the holes below
10 or 13mm socket (i can't remember it varies between rs's and cooking models) on a 3" extension up the two lefthand holes to get the nuts off.
then i take it I have to undo the bolt below and 1 the other end to get the fuel rail off?
Indeedy
Is that a glimpse of the injector I can see just to the left of that bolt (copper shine)?
Thats the clip that retains the injector onto the rail but near enough yes. Its a steel clip its just rusted.
