Register a free account today to become a member! Once signed in, you'll be able to participate on this site by adding your own topics and posts, as well as connect with other members through your own private inbox!
Just about to change the oil on my 172 and wondered should I flush the engine inbetween oils? Also think I got a noisy lifter so is it worth putting some of that sticky lifter treatment stuff in?
you can flush it if you want buddy, theres no point in doin it on every oil change. top end treatment would be ok, i always put it in an do a few miles. then change the oil
IMO, flush is the creation of the devil.
It is potentially very damaging stuff. Good quality oil changed at the correct times dependant on use and abuse is all you should really need.
yea get all set up at home then get the oil realy hot and drop it...
just be care full you dont BURN yourself while its hot and thinner it will flush out more bits of crap........ dont know if anything will sort out your lifter though apart from replacement
i flushed mine last time i changed the oil but nothing came out so was probly a waste of time. only real way to clean it safely would be to take it apart i assume. but iff you give you car the beans on a regular basis then you should be ok.
but if you do decide to flush it then use forte` engine flush. its what the pro`s use
