If you're in a hurry and can't wait, get a hairdryer on it to warm the block up a little, surrounding pipes, etc. Don't know whether it helps but it seems to get my neighbours 206 shite working everytime. Was it running ok yesterday or has it been left for a few days?
No was fine yesterday no probs. i borrowed the wifes c max to get to work but had to push mine off the driveway first. have you ever tried pushing a car uphill on ice by yourself? i think i've put my back out.....
LOL. No, I haven't but I can imagine it's not good.
Hmmm, give the hairdryer thing a blast tonight on the block, pipes and battery. If the battery is too cold it'll have few electrons so not enough to power the starter motor. Warming the block will also help with warming the oil.
Aye if it's on a hill and all the petrol is drained to the back/front of the tank away from the bit where it sucks it out of the tank (technical I know). Try and get it on the flat if that's the case.
it was on a slight hill, nose pointing down. computer says 50 miles left. I might just get some sparkplugs and a gallon of petrol on the way home. If that doesn't work i'll call the AA later tonight.
did you run the 'warning' lights sequence on the dash.
Im curious as this happened to me and it wouldnt fire, just the key would go round to the 4th notch and do nada as if it was about to crank and spark.
lmao at the hairdryer trick. You would have to stand there for about a week before you got any temperature. Even then Heating the Engine would make no difference.
Does Maybe sound like its lack of fuel.
If it Turns over its not the Starter, so like someone has said check for fuel and spark.
Also maybe give the TDC(Flywheel Sensor) a wiggle??
What? You mean a hairdryer can't get an engine up to temperature? Well I never.
Being on a slant with little fuel is very tempremental in some cars, my old 1.2 I used to get that a lot and had to park it on the flat when it was low on petrol.
Did you push it onto the flat then, Clart? Or back onto the slant on the drive?
Lots of canadians/ those in cold states heat the block. You'd be stood there a while, but if you could balance it somewhere and leave it running it might help.
just sent the wife to get some petrol in a jerry can - started first time. I don't understand why it didn't start when it was parking on a flat road if the computer still said 50 miles left.
Lesson learnt - do not park on even the smallest slope with under 50 miles worth of petrol left!
