Any updates
Not really, went home to Cornwall for xmas, then the snow got in the way :dapprove:
Last night i realised that theres not actually that long until Llandow though (Thursday 25th March) & i don't currently have a car to do it in!! As such i thought i better make a list of what still needs doing:
Done:
1. Fit new front & rear bumpers
2. Strip interior back to metal
3. Remove all sound deadening, rear wiper & fog lights
4. Fit new steering wheel & seats
5. Partially fit new exhaust
6. Replaced wheels/tyres with MOT friendly ones
To do prior to MOT:
1. Install roll cage, tidy up interior wiring (2 hours)
2. Finalise seating position & fit harnesses (1 hour)
3. Remove interior surface rust near rear tailgate (1 hour)
4. Change manifold, catalytic converter & lambda sensor (3 hours)
5. Fit new rear discs/pads & free up drivers side caliper (2 hours)
6. Change to Gti6 front calipers, discs/pads & replace drivers side abs sensor (3 hours)
7. Install Gti6 master cylinder, braided brake lines front/rear & bleed brakes (2 hours)
8. Fit quickshift to gear linkage (30 minutes)
9. Add OMP lower front strut brace (20 minutes)
10. Tidy up engine bay, ensuring that all replaced parts are securely tightened (20 minutes)
11. Full service including spark plugs, fuel filter & oil change, maybe cambelt depending on wear (2 hours)
After MOT:
1. Fit Spax suspension & fine tune to suit driving style (3 hours)
2. Install Magnex de-cat pipe (30 minutes)
As you can see, its clear i need to get on with it a bit
