The everlasting ph1 ITB Build **GREEN-BUILD STARTS AT PAGE 100**
Re: someph-ing different...........
Maybe a silly question but are you still running the 428's? Interested to see the dyno results if so. :)
That bay is cracking. Have the black parts been spray painted or powder coated? I need more pictures :) closer pics of the bracket would be cool too :)
Ktec had a very similar bracket on there engine.
Think we are going to make one for our new engine. Very good idea.
chrispy, i can answer this one :) its VHT paint, can buy it in halfords an stuff. mines covered in the same stuff
halford stuff is s**t just to warn you, the stuff i use is what they use at cosworth
k-tec's might be inexpensive, my one cost a few quid LOL!
i am indeed running the 428's still....will post results
bracket is a great idea, nice and out of the way
need a new battery now though, unsure whether to go redtop or not, then is so where to put it...
I don't think the "normal" battery looks out of place in your engine bay.... all looks very neat as is!
Although it does look a smaller size that other 172/182 batteries I have seen :S
looks mint at the nec
was looking for you on the sat to say hi
was you round??
feebs
i think it was the standard size battery, trying now to decide whether its worth getting a red-top and moving it, what the advantages / dis-advantages are...
was you round??
feebs
i got back up there on the sunday so you wouldn't of found me, sorry
Advantage- Typically an 8kg weight saving
Dis-advantage- Can be prone to losing charge, cost, you'd be better off moving it in the car in a proper tray or making something pimp up in the bay to hold it.
If you're not fussed about weight fella, I wouldn't bother! Was good catching up aswell, lol.
Fabricated as a one off prototype the one on Neil's car = ££££
hopefully my production version, like your's will also be less expensive!
i have classed the car in its current spec as Stage 1 (which i consider complete), in stage 2 (when i have another car) the clio will be loosing weight rapidly so weight is something i may aswell think about now yes, thinking may be best under the passenger seat, more room for nothing in the engine bay then...lol
deffo good catching up dave, your a top bloke, good to know there are still some on here...lol
I'd invest then, weight saved and better distributed.
And you dude, we're in the elite I think, lo.
Oi ya feckers, I'm a nice guy too. Who else bought you a wind up music box on Sunday lol?
May as well take advantage of upgrading to a smaller battery, I'm going to smack one just behind the passenger seat, just to make it a bit easier to access should I ever need to. You can probget a deal on them anyway, but burp is sponsored by a battery firm nowand has a group buy going on another forum
I noticed one of the companies at autosport where selling the red top 25's considerabily cheaper than most places, can't remember the name though!
How much does jay (Burp) do them for?
car looks brilliant!
fred/neil - what are you doing about the engine mount fixings that are no longer utilised due to the ITB's?
i have tried purchasing these parts seperately (a bolt and tapered washer/spacer setup for one fixing and some sort of bracket that bolts to the block and lower cam cover on the other) but i cannot source them due to not buying an off the shelf kit
is there a solution you are planning? (i am willing to purchase these items immediately!)
i remember at FCS when Fred and Icarus were checking over ben_p's car that you noticed the crack in the engine mount and advised him to sort it out as it was causing excessive engine movement that would prob lead to cracking the lower cam cover, i dont want to cause the same problem :)
ben's was from another issue
you on about the bit where the 2 bolts go into the lower inlet (on a standard car)
never had a problem with it before, but i've got something in the pipeline
yep looking into it now, them and some new HT Leads too, indeed i think we are in the elite...lol
indeed mate you are also in the elite...you are a nice guy (everybody i showed the music box loved it)
burps price i think is...£86 for a odyssey PC680 couriered to me
ah i see
yes thats the bit i mean :)
i won't clog up this thread any further, but if you could keep me informed Fred that would be brilliant
Got any of the front low down so we can see the inlet??
just for you dan...but none with bumper on yet...(you can just see it in the picture at the bottom)
stumbled across this in flickr earlier, thought you might want the link as its a decent res picture.....
http://www.flickr.com/photos/fuzzy_orange/4285449245/sizes/l/
ideal for a wallpaper.... ;)
thats awesome, thank you very much
you could of tidied up the breather plate FFS
you could of popped and helped us do that before autosport....it was tight as it was, its gone back to be finished off anyways,
what was wrong with it anyways?
there are brackets for the inlet manifold that are not needed anymore and also carbon canister bit can be tidied :D
but the work looks a1
being low is it now not a puddle scoop though???
