after a rebuilt - done 700mile now but the engine dont sound right.
Had the car reserviced 2weeks ago from them.
Is their anyone local can have a quick look, as maybe its just in my head.
I live in eastlondon near startford and Im happy to meet up.
when running sounds diesel and tapping that concerns me. I just had the lambda sensor done at Ren7aoks and was hoping it will go away after that, plus i didnt notice it much before as the exhaust was too loud before.
gotta be someone on here that came meet up or take a look
Lamba sensor won't make a blind bit of difference to a 'tapping' engine.
Sounds suspiciously like oil starvation to me, IIRC your old engine was a gonna due to low oil yes? I would check the dipstick if I was you. DP pulley is also a likely cause.
When it's been driven or turned over the oil on the dipstick looks alot lower then if it's been left to sit and gather in the sump. I checked my oil one morning and it was on the top level of the dipstick. Turned it over and for one reason or another I looked at it again and it looked very low. So be careful. Don't want to over fill it.
Inlet pulley all day long that noise!
And Maz, 95% of 172's leak oil from the rocker covers, its renaults little mistake of building them with s**t roll on sealer! I would also imagine the warranty you have will not cover any items that have been caused by naglect. (not checking oil etc)
they may suffer frm oil leaks but mine was serviced 2weeks ago by them.
Thats why i didnt even stop to think the noise cud be the oil. I topped it up with abit of oil just to Stay safe.
Just because it was serviced doesn't mean they have to fix the leak. If it was a good enough garage they should of produced you with a visual health check sheet. Any raised concern's should of been noted and then passed to you for authorisation to carry out the work. Ive seen a good few clio's also suffer from rear main oil seals, check on the undertray for any signs. It can be easily confused with weeping gearbox's though! Give R Sport a shout and get it booked in, there down london way and are good with renaultsport's!!
