Emmissions light on
Car  clio 182
The emmissions light is on all the time on my 182. It usually Comes on n goes off again when u turned engine on n off. But since coming home the motorway it came on n now it won't go off. Running a ktec ultra zorst n decat.
It safe to drive?
+1 ^^
mine came on yesterday after a trip down the a1 its the second time it's come on, both times have been using cruise control any relevance ?
It's safe to drive, it's because the post cat O2 sensor is detecting high emissions due to your decat.
Mine used to do it on a regular basis. With and without decat. Wouldn't worry about it.
seems fine , no loss of power , it idles ok plus had the coil pack changed about three months ago.
If you want a new sensor, NW Performance are the cheapest I've found.
You can fit it in aout 10 minutes too.
Oh ok, the dealer sorted it out n it just came on n is now staying on even after turning on n off. I was using the speed limiter.
I have only had new coil pack n sparkies 3days ago.
Ok just wanted to check as I gota work all week this week.
