Where to buy new Lambda sensor?
Do i need two Ryan or will it be the one on my Decat?
So fed up with this car, havent driven it since i was last down with you :(
It could be!
Do you know anyone else with a 172/182? Try there map sensor on your car see if that makes a difference.
Yeah theres a couple round here, dont know how/where the map sensor is though, also i canty drive my car, no MOT :\
Its on the side of the plenum next to the R. Take it out and give it a clean.
p.s Your sensor will be with you within the next 48 hours.
Ok cheers :) Now i need to work out how to change this Stalk over to this ph1 i bought, Oh the joys of modding cars and not having a clue what your doing!
Be careful when you remove the map sensor mate. If you yank if out you will snap it.
Ease it out slowly
I use WD40 and a lint free cloth - Micro fiber or something. Clean it with anything really though, can't see it doing any harm no matter what you use as long as it goes back in clean.
Ok spot on, think i might go give the car a good clean over now anyway, give me something to do on my skiving day off aha :)
Also Ryan, could you post my Coilover spanner thing along with the sensor?
Then lambda's are the same Stuart, you can swap the back to the front to eliminate that.
I think I have a 'faulty' MAP sensor somewhere that I could send you to try?
