3 inch 3 point harnesses or where to mount 4 points?
  • Thread starter Thread starter JB
  • Start date Start date
JB
Car  RB 182 Cup
I'm after some harnesses with 3 inch shoulder straps and was wondering if anywhere sells that size on a 3 point harness.
Alternatively, how hard is it to fit 4 point harnesses with regards to securing the rear bolts. Do spreader plates need to be welded in?
The harnesses will be going in with Bimarco Futuras on JMS subframes.
Thanks.
as far as i know people do a 3" 3 pointer, couldnt tell you who though
think you can the side rear belt mount and if you've removed the isofix you can use one of those bolt holes
ed
Sorry don't quite know what you mean. Are there enough fixing points currently for 4 securing bolts on the floor plan?
I have a 4 point harness (with Bimarcos btw). I mounted the front two points in holes I drilled in a good spot just behind the seat.
The rears were easily mounted in the holes that the ISOFIX bar attached to.
All were secured using proper spreader plates etc
This is where i mounted my harnesses.
I can mount my two front points in holes in the seat subframes.
I did have 3 points in which the rear bolts were mounted in the hole where the seatbelt clips are screwed in.
There are 2 more holes which I can screw in the other harness ends? Or have you mounted just 1 harness?
Chrispy.clio, any more pics in detail of where you mounted those?
I'm after these, I presume they'll fit ok and look good in blue:
http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=SAB901118E
My rear ones are the same as Chrispy's.
I'd watch the front ones though, I WAS going to mount them in the holes where the seats came out but I think they were too far forward to work well.
Cheers guys. I've bought some 4 points so I will see if they fit when they arrive.
Then no doubt post up here again asking for help :o
every one i know with 4 point just use the iso fix bar mounts,
and the bolts where the clips bolt to the floor plan
