ph1 track weapon
Noticed a knocking from the passenger rear the other day which hasnt gone away
initially thought it was a loose wheel, so removed/refitted/tightened but to no avail
next though it was a blown shock. only replaced both rears 2k ago and its not showing any of the symptoms it did when it went before
also checked the exhaust to see if that was knocking on anything, again no obvious problem!
rear pads look low, but doubt they'd knock
last thing i guess it could be is a kanckered wheel bearing, but no idea what that would sound like?
On a side note, i do find the front is starting to feel a little loose. where are the bushes on the front end and how could i tell if theyre dead?
many thanks in advance
ed
ed
