Clock Display HELP
Rubicon_
Car  L110, RS6, Westfield
Basically the other day i decided to take the dash off and have a look behind the clock. I done this because a girl from work needs a bulb changed so i practiced on mine to see how easy it was. Everything was fine, i took the 2 bulbs out and then replaced. Once back together plugged the battery back and and started up... No clock display now lol radio and everything else still working just no time or temp on the display :S could this be a fuse problem or have i damaged an important part behind it ha
Take the bulbs out and try them in the other way if you get what i mean, twisting them 180 degrees
cool al try that, see after i start up to check if not working do i have to wait 25 mins again befre i start fiddling with wires?
you dont need to disconnect the battery or anything tbh. whe i changed all my dash lights including clock display etc i never disconnected the battery. i still had the ignition on when i swapped the bulbs in the clocks. you will be fine.
No you'll be fine mate. Pretty sure its just the bulbsare the wrong way rond. If not, silly question but you sure you plugged the connecters back in?
cheers guys, had a closer look must be the bulbs as when a light is shone on it i can make out the digits sgtill... relieve :D
