Ktec Coilover Pic Request
Car  Discounted 1*2 parts
As above, 1*2's with the ktec coilover kit fitted. Want to know whether its gunna go low enough for my liking.
i think they go low enough mate but a lot of people said the spring/damper rates are quite soft so they catch easily
mine is pretty much all the way down on the front and it rarely catches when booting it round a corner
ive got vmaxx mate sorry should have said
on 15's mate, with no rear adjusters in
ive also got some pics of it when it was a bit higher on 16's if it helps, had custom rear springs but all the rear was stripped out so had no weight in it
I never had any rubbing issue's with the front on the 16s, just when i put it on the 15's and lowered it a further 30mm
If you get them you won't set them to the lowest setting
If you do, you won't get very far lol :p
search The Boosh! as he has K-Tec coily's fitted and a few good pic's of his car... Da also has them fitted
They are fine for the money but I would just save up for a decent set, I have them due to needing a set quick after my Gaz Golds lost all their oil :/ You cant lower the front a decent ammount and still be able to corner hard without massive ammounts of rubbing, rear end wise they are decent enough height wise if you still have seats etc in, I dont but im using the springs from my Gaz golds so it sits about right all around. Now all setup and with the front slightly higher my car handles really nicely and im happy enough with them :)
I've been impressed with them so far. Mine could down down about 15/20mm more on the back I think.
Edd im in love ;) Black ph1's are sooo nice, red wheels and details look spot on as well! ;)
What's up with it? Can I just have the spoiler then!
go vmaxx mate you wont look back, never had any issue's with mine
They were set at this and Im sure i wound them down a bit more since the pic was took
They go more than low enough!
This was my Cup...
And this is my 172...
My Cup did rub at the front if cornering hard but my 172 doesn't... It could go a lot lower!
Yeah but not that much wider... It's mainly due to me raising the front slightly on my 172. But you are right.
I wasnt trying to be a c**t about it :D just saying... :) But ye with my 15mm spacers I have to leave a little gap at the front as it rubbed like mad when driving properly, luckily all setup nicely now and my handling is epic!
