D dancook Car Clio 1.5dci Apr 10, 2010 #1 I changed spark plugs and when I turn engine on it revs up to the red, if I would have let it that is. What have I done? On a dead line to leave and missus ain't happy thanks guys
Daniel ClioSport Moderator Car Whichever has fuel Apr 10, 2010 #2 You've got an air leak on the inlet manifold I expect. If its a 182 you've not got cable throttle so its not that jamming anywhere. Take it all apart and put it back together again. Properly.
davebem Car Lots of Alfas Apr 10, 2010 #3 182 doesnt have a cable throttle, as above it could be an air leak or something isnt bolted down tight enough.
N NWPerformance Car Various Apr 10, 2010 #5 Sounds like you haven't put the seal back on thats on the underside where the coil pack is. Its shaped like a rain drop made of rubber.
D dancook Car Clio 1.5dci Apr 10, 2010 #6 Thanks all, cheers fred. It was that oval ring that had fallen when I took it apart. Crisis averted!! Car is running fine again Don't go anywhere though, fitting my cat tomorrow.
ipodsandguns ClioSport Club Member Car GW X200 CUP Apr 10, 2010 #7 NWPerformance said: Sounds like you haven't put the seal back on thats on the underside where the coil pack is. Its shaped like a rain drop made of rubber. Click to expand... Whats this seal do? i often question it? i look at it and think 'right thats defo got to be sealed, if so why is it there?'
