oil leak, pics
Waltz172
I have noticed oil sitting underneath the manifold, then inspected futher and found that oil is seeping out of the join all the way round the engine block
any help on what has caused this and what i need to do to fix this
thanks
Liam
Waltz172
rocker cover gaskets tend to weep on them, dont let it worry you unless its loosing a fair bit.
in 5k miles it ran dry but i got told these engines do like a bit of oil so didnt really take any notice until i saw it weeping out
  silver Ph1 172
have u not bothered to replace it then, or you just keep topping the oil up?
Tbh, I have not had this one long so I haven't got round to doing it yet, I'm gunna do it when I change the plugs in a couple of weeks
Waltz172
no gasket, its just silicone type sealant
big job to sort out if it is the rocker cover and not just a few of the bolts
new cambelt etc etc, knocking on the door of £500
how can i tell if its the rocker cover and not just some bolts?
  Lionel Richie
you'll see oil pooled round the bolts, whip each one out (one at a time! NOT all at once) silicone the head and mop up the oil and torque it back in (14nm)
Waltz172
if it is the bolts then would you still get the oil leaking out of the join in the cover, surely you would only see it coming out throught the bolts? i just think theres too much oil being lost for it being the bolts?
Waltz172
ok but wouldnt the oil jus come out through where the bolts are and not the join in the cover, shown in the first pic?
Waltz172
ok hopefully it will last another 50k as ive just had belts done,
at the mo im doin 1ltr per 1k miles
