Can I get rid of this & how (pic inside)
  TrackCar & F30 330d
This little strip of metal is quite annoying and i want to know if i can get rid of it as i'm having a full weld in cage. How can i get it off? Do you sort of drill the spot welds a little bit with a big drill piece?
  M3 Touring
Drill the spot welds out yeah..
I am not sure what is underneath it though / it's purpose?!
  TrackCar & F30 330d
Well i'm assuming its for strength but the cage does have 9-11 points that weld to the car and 4 gussets so i'm adding quite a bit of extra support :)
And it doesnt have one on the passengers side!
  BMW E30 325iiiiii
i think its just add a bit more stiffness in case of an accident, just to stop the floor coming up and forcing ur knees into the dash. I doubt that it would be seriously strong to do that, but, every little helps.
  Dodgy one
THIS, You'l want a spot weld drill bit to remove it unless you want loads of holes in your floor!
and its most probrably bonded on too, I'd be surprised if it is'nt.
  BMW E30 325iiiiii
yea a 6mm drill bit, hammer and chisel, and ur good to go.
also, if u get a piece of sand paper and rub it down a wee bit up the edges, it'll help show more of the spotwelds, incase u miss one and feck the floor.
