Rico Car GW 200 May 20, 2010 #1 Got some oem locking wheel nuts for my 182. Are they identical to the ones fitted on a ph1 V6 clio? Will they fit? Thanks.
Rico Car GW 200 May 20, 2010 #3 jesus said: Aren't vees 5-stud? Click to expand... no idea, thats what im trying to find out. Never even been in a vee, never mind inspected the alloys :rasp:
drhowser Car lift number 1 @ btm May 20, 2010 #4 Compare them to the bolts you have? As long as they are the same length they should be fine.
Rico Car GW 200 May 20, 2010 #5 drhowser said: Compare them to the bolts you have? As long as they are the same length they should be fine. Click to expand... I dont have any to compare, only mine from the 182.
drhowser Car lift number 1 @ btm May 20, 2010 #6 Right. As far as I can remember they are the same, vee is five stud but i think the bolts are the same. Don't quote me on it though. I might have some bolts from a vee outside, hang on.
Rico Car GW 200 May 20, 2010 #7 I believe the 182 is 4x100. But i guess as long as they are the same width and length they'll be fine on a ph1 vee.
drhowser Car lift number 1 @ btm May 20, 2010 #9 4x100 is the bolt spacing, that's to do with the wheels, not the bolts themselves. If the offset is different then the length of the bolts could be different, but the pitch and diameter will 99% be the same.
drhowser Car lift number 1 @ btm May 20, 2010 #11 http://www.wheelfittingsolutions.co.uk/Renault-Clio-V6-Wheel-bolts-set-of-20-p-212.html v6 http://www.wheelfittingsolutions.co.uk/Renault-Clio-Wheel-bolts-set-of-16-p-205.html clio I don't have any to compare, but the above says no. I did think they were the same though...
drhowser Car lift number 1 @ btm May 20, 2010 #12 jesus said: Check v6's don't use studs too first. Click to expand... Definately bolts dude, that much I am sure of.
A arney101 Car V6 PH1 May 20, 2010 #13 they are definately bolts and 5 of but would like to know if they are the same, that website seems to think not though
