182 locking wheel nuts ok to use on V6 ph1?
  GW 200
Got some oem locking wheel nuts for my 182. Are they identical to the ones fitted on a ph1 V6 clio? Will they fit?
Thanks.
  lift number 1 @ btm
Compare them to the bolts you have?
As long as they are the same length they should be fine.
  lift number 1 @ btm
Right.
As far as I can remember they are the same, vee is five stud but i think the bolts are the same. Don't quote me on it though.
I might have some bolts from a vee outside, hang on.
  GW 200
I believe the 182 is 4x100. But i guess as long as they are the same width and length they'll be fine on a ph1 vee.
  lift number 1 @ btm
4x100 is the bolt spacing, that's to do with the wheels, not the bolts themselves.
If the offset is different then the length of the bolts could be different, but the pitch and diameter will 99% be the same.
  V6 PH1
they are definately bolts and 5 of but would like to know if they are the same, that website seems to think not though
