editing a pdf?
Car  soon to be 172
I managed to send off my pdf the other day but he has returned it and i need to make amendments. He said hes not in the office so cant resend it as a normal doc and it needs to be back with him before 4:30 otherwise i will incure another day charge for himresending it monday.
Free programme if possible.
I use Adobe Acrobat 8 Standard at work and I can edit PDF's. It depends on what was originally used to create them, but, in general, for what I use it for it's fine.
I doubt it's free, but it may be cheaper than any charges.
What is it a PDF of? If you originally created it, then can't you just do another one with the amendments?
If you send it to me, I'll do it for you if you're struggling.
And it's not much editing.
I have Acrobat Pro, but I normally use Adobe Illustrator.
Tools > Advanced Editing > TouchUp Object Tool
Select the area you want to edit, whether it's text or vector, right click, Edit Object/Artefact. It will then open in Illustrator and away you go.
When edited just do CMD-S or File > Save if on a PC, give it a few seconds then flick back to your PDF.
Edit complete :D
/me hugs CS5 !
