iPhone problem
Car  Gentlemans spec 200
Can't put any music on, or access any music on the phone, looks like this in itunes
Any idea's?
I have similar issues but I may just be being a complete n0ob....... Cant get music from iTunes library to the iPhone
Reset the phone and computer and try again.
Have you moved any music to a different hard drive or anything?
If that all fails, try what Jenic says and restore it.
Since you last synced you've moved it?
iTunes think it's a different library now.
There is a way to change it, lemme see if I can find it..
Your iTunes library database has been deleted or corrupted. iTunes makes backups of it and if you rename the latest one to the right name it'll work.
No idea where it's stored on windows as I don't use it on windows, should be easy enough to find though.
Ok, resynced with itunes (ie lost music on the iphone). All fine and dandy, put my albums back on. Just reconnected and it's doing the same again???? So I'm having to resync etc on every f**king connection??
Clues?
