ETS - http://www.edentyresales.co.uk/
The Alfreton Road, Derby branch has a Hunter 4 wheel alignment system. Should sort you out so long as you know the geometry settings you want your car set to.
If you dont tell them how you want it, they will just give you the generic Clio Sport setting which while correct, depending on how low you go down it wont be correct for your car anymore. Have a search on here for the geometry settings, im sure its been covered in the past.
Tyres 4 U in Mansfield.
They were spot on with me, much better than Demon Tweeks.
They've got the exact same laser alignment system, but they'll set the geometrey up to what you want.
Depends what you want. Only the front is adjustable in terms of camber and toe. They know what they're doing with toe, so camber is the only real choice you have to make![]()
www.alignmycar.com
check for you're nearest centre...
Tyre 4 U Ltd (HawkEyeAlign)
7 Anglian Way
Southwell Road West
MANSFIELD
Nottinghamshire
NG18 4LP
Top guys there, they set my 172 up a couple of times! go out try the set-up, go back and have a chat with them about the set-up and they will adjust until it is what you want![]()
Better turn-in and steering response really..bit of negative camber helps resist tire sidewall rollover which means more tread in contact with the road i.e. better cornering traction.
