How much were they ?
Are you fitting them yourself ?
weather permitting i will be fitting them tomoz![]()
What size drop is that ? And are you running spacers or camber bolts with that standard rims ?
Cheers![]()
My drops about 60/70mm I think.
Running both spacers and camber bolts![]()
Cheers![]()
What size spacers you running ? And did you have any problems with the camber bolts because iv heard they can be a bit of a pain on the rokkors![]()
25mm spacers each side, and camber bolts were fine, took about 30mins to fit each side, and doing a pikey "that looks about the same as the other side".
In all reality, i just put as much on as I could.
I have wider wheels nearly ready to go on, just need to stretch the rubber on the wheels, so I may have my 25mm spacers up for sale as I will probs need smaller ones.
Keep on topic. No chat, just pics. Your rules.
Jesting.
